Another Mountain Electronics SolarForce flashlight.
Woods Walker
The Wood is cut, The Bacon is cooked, Now it’s tim
New England woods.
I got the body free with another purchase from SolarForce. Combined that with extra parts in the house and a MT Electronics Warm P60 Drop-in. Inexpensive so don't need to worry about it like a nice C2. Not that it's not ok but you know what I mean. I tested the body when empty and it was waterproof.
http://www.mtnelectronics.com/index.php?route=product/category&path=86
Good beam profile with some throw.
bykfixer
Dust in the Wind
Did you have any connectivity issues using the MtElec drop in with a SolarForce?
Every type of drop in I've used in one had to be slightly modified to work. Easy enough to do using various methods.
I was just curious if your drop in needed any.
Thanks for the thread.
Btw, my favorite fix is a gap filler between the lens and module like an o-ring or Malkoff Scout head adapter to push the module a bit farther into the Solar Force. Others have ideas that work too (like wrapping the module with foil), but that's the way that works best for me.
Woods Walker
New England woods.
I wrapped this in Al foil but don't remember having a problem when testing a 4-Mode NW. Then again only ran it for a short time before wrapping that as well. Seems to be pushing against the window just fine. I did need to add an outer spring from a cheap LED drop-in to make a Malkoff work in the SolarForce.
