Another SL-35X possibility...
Dukester
Washington State
I did the math and you should be able to fit 8 (NiMH 1/2 D's). Depending if I get the 1/2 D's from BatteryWholeSale That is a whopping 3.5ah 9.6v Stick. I am wondering if the 20watt bulb will handle such a draw? I have been told that the 20watt bulb is robust enough to go up to I believe 12v?
I doubt it would take it, Duke. Hot off the charger, an 8-cell stick would be 10.8V or better. I doubt the 5V nominal SL-35X LA would take 100% overdrive.
If someone has experience running it at this level, please chime in.
Wilkey
Wilkey, nominal voltage for 35X LA is 6 volts, and runs really good with 6 NiMH. I think can handle two more NiMH oK. I will section my old stripped SL35 for two extensions for two more NiMH C's, one at a time I will test. Who knows......
Bill
Oops! I'm sorry. Had a momentary mind fart there. You're right. Let me know how it goes. If it works on 7, could bode well for an even more intense MC mod.
Wilkey
The SL35 is a boat of a light, too big IMO. I am upgrading the stick in my SL20 to NiMh for imcreased runtime since I run the SL35 lamp in it. Absolutely love this setup, keep it in my truck. Doubles as an attitude adjuster too. /ubbthreads/images/graemlins/twakfl.gif
SL-35 will draw 3.6A using 6x1/2D
SL-35 will draw ???A using 7x1/2D Anybody has tried yet?
SL-35 will draw ???A using 8x1/2D Anybody wants to try?
[ QUOTE ]
[/ QUOTE ]
I will more than likely try it but it won't be for another month or two. I think but I could be wrong but I think the mighty SL-35X would be able to take the additional voltage. It will be an interesting test to perform. That 20watt Halogen would be awesome to view while over driven! /ubbthreads/images/graemlins/grin.gif
I will try it but using NiMH C's in a SL35X with extensions from a stripped SL35. Will take me a week or so before I get around to it.
Bill
V.H.,how test? Testing would involve a fair amount of run time, and some on offs to see if it would flash. I don't have any 1/2D's, so would need at least one extension to test with C's. Maybe I am tired. Help me here. I runs ok weth 6 C's.
Bill
Bill, you can use some rolled cardboard for temporary hold 7C and use low resistance wire from negative to body instead of cap and spring to run a test.
Unfortunately, I do not have a SL-35
I do, but it's my only one and I don't want to blow it. I would do as 5M suggests before you go further with machine work but it's up to you. Remember, the cells you use will also be a factor in whether it survives. I think it would survive 8xAA but only because of the massive voltage drop. 8x1/2D nimh, I'm thinking no but would be delightfully surprised.
Wilkey
Six 4.5mAh C's are pulling 3.5 amps in my SL35. I notice that increasing voltage in incandescents does not raise amperage by much. They really are voltage driven. At least in my experience. Voltage is 2.5 X 6.
Bill
V.H., I hear you. I was thinking a test with more real world use. Banging around and all.
Bill
