This is a 5 cell (plus one dummy cell) Nimh 4/5A 2000mAh battery pack. I built it out of a 7 cell airsoft nun chuck battery pack which I got cheap from ebay. It was a straightforward build and the end contacts were the only parts that required soldering. The battery contacts are made from a steel biscuit tin and bits of red and black card so that the charging magnets stick to it. I'm using the team orion IQ605 model charger at 2 A.
This pack drives the MN21 bulb at roughly the same output as the stock 9V li primary pack. The MN21 is way overdriven on 2 x li-ion or 6 x Nimh, so I figured 5 x NiMh was the way to go. Runs for about 15mins. There are more powerful and longer running mods out there e.g. 1185 w/3X17670 but I like the beam pattern of the MN21. It gives a nice diffuse round circle. Also there's no sudden cutout with a NiMh pack.
