Any backpacking headlamps lighter/brighter than Zebralight H51 Headlamp AA 200Lm?
mountainwalker
Can anyone suggest any lighter/brighter/better backpacking headlamps than the Zebralight H51 200Lm model below? Just wanted to know if there's anything out there that's better than this model, which is the current gold standard I'm familiar with of power/throw/longevity/adjustability for the very light weight.
http://www.zebralight.com/H51-Headla...00Lm_p_37.html
Oct 23, 2010 Update: The second sub-level of the High is expanded to include 140Lm, 100Lm and a 4Hz strobe.
Main Features and Specifications
LED: Cree XP-G Cool White (color temperature 6100-6500 K)
User Selectable Levels: 3 main level (High, Medium and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of the High can be further configured to different brightness levels or strobes.
Light Output
High: H1 200 Lm (0.9 hrs) or H2 140 Lm (1.7 hrs) / 100 Lm (2.4 hrs) / 4Hz Strobe
Medium: M1 30 Lm (12 hrs) or M2 8 Lm (39 hrs)
Low: L1 2.5 Lm (3 days) or L2 0.2 Lm (16 days)
Light output are out the front (OTF) values. Runtime tests are done using Sanyo 2000mAh Eneloop AA batteries.
200, 140, 30, 8 and 2.5 Lumen output are current regulated. 100 and 0.2 Lumen output are PWM generated.
Voltages: 0.7V - 2.5V
Battery: One 1.5V AA (NiMH, lithium or alkaline). 14500 Li-ion batteries are not supported. Batteries are not included in the package.
Parasitic Drain: Negligible (equivalent to 16 years)
Beam Type
80° spill beam spread
11° (3.8 feet at 20 feet) hot spot
Diameter: 0.90 inch (23 mm)
Length: 3.2 inch (81 mm)
Weight
1.2 oz (35.8 gram)
2.2 oz (61.9 gram) with an Eneloop AA
3.0 oz (84.9 gram) with an Eneloop AA and headband
Features
Electronic soft-touch switch, with a 200,000 cycle operating life
Smart user interface provides fast and easy access to all brightness levels
Precision machined unibody casing from premium grade Alcoa aluminum bar stock
Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing, providing unblocked thermal paths to over 94% of the surface area.
Durable natural hard anodized finish (Type III Class I)
SCHOTT ultra clear lens with anti-reflection coatings on both sides
Orange peel textured reflector
Glow In The Dark (GITD) silicone ring near the tail cap
Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain
Waterproof to IPX8 (1 meter 30 minutes)
Operations
This light has 3 main levels (High, Medium, and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of the High can be further configured to different brightness levels or strobes.
Basic Operation
Short click turns on the light to High or turns off the light.
Long click (press and hold for about 0.6 seconds) turns on the light to Low.
Advanced Operation and Configuration
Short click turns on the light to High. Short click again quickly to cycle from High to Medium, and Low.
Press and hold to cycle from Low to High, release to set. When press and hold, the light always cycle from Low to High regardless which level you are currently in.
Double click to toggle and select between the two sub-levels for that main level. Sub-level selections (except the strobe) for the 3 main levels are memorized after the light is turned off and through battery changes.
The second sub-level of the High can be configured after 6 double clicks. Double click (startng with the 7th) to cycle and select different brightness levels or strobes. Short click to turn off the light when finishing configurations. The selections for the second sub-level of the High are memorized after the light is turned off and through battery changes.
Accessories in the package
Removable pocket (H31) clip
One black silicone holder with headband
One GITD silicone holder
Two o-rings
Extra GITD and black silicone rings
