palomino77
I am not one to try to get 3 years of use out of a cheap (low cost) cell. I like a 95-100% full charge each and every time I charge a cell. I don't want to have to roll, pull and reinsert or reset in order to get the charge I want.
Whenever you or I put two cells in a two-bay charger, we should get, on completion, two fully (or close) charged cells with matching voltages. Not one cell having 4.20v and the other with 4.12 or 4.16v. When this happens, you have to perform one of the above actions to get the voltage up to match the other cell. Good luck with that. It is a nuisance, a bother and a waste of time.
I have only had only one charger so far that would charge to 4.20v. per cell, 100% full charge each time. After about 10 charge cycles it burned out Just my luck.The other chargers I have either overcharge or are inconsistant (uneven termination voltages).
It is important to always check the cells' voltage coming off any charger to be sure the cells are closely matched.:twothumbs Matching cells' capacities is another story altogether.......
I only have AA flashlights right now and I was thinking of buying an M1X and a jet III military,, but lately with so much hassle about using Li-ion batteries, with so many warnings about explosions, fires, keeping a eye on charging because your life depends on it, etc etc. and now your comments on two batteries having be the same voltage,,, is really killing the passion for wanting one. right now I'm thinking about just sticking to AA flashlights. With AA's I just charge (leave on charger for days), buy or get crap cells anywhere I want and the thing lights up. Can you imagine if AA's where the same as li-ions and owning a TK40 with eight batteries. Or maybe things aren't that bad and it is worth it, I'll just have to keep reading and think about it.
