It's basically a smaller and somewhat brighter version of XP-E2, might just be the best LED for compact throwers. Yet I don't remember a single light advertised as based on this emitter. Why might that be? Am I missing something important here?
XB-D is not using remote phosphor, remote phosphor would mean using a blue LED the like the XT-E Royal Blue and the applying phosphor to the lens of the device.
The phosphor IS on the die.It is considered a remote phosphor device as the phosphor is not applied directly to the LED die but to the dome of the LED. This in turn acts the same way as you have described but at the component level. This is what is leading to the colour separation that the others have observed.
The phosphor is on the die and all over the base of the LED. It's a layer between the LED base and the silicone dome which covers the entire base.
What he said... therefore it acts as a remote phosphor system and thus gets the designation. The XT-E white also does the same thing I believe.
So then every white LED would be remote phosphor. It's just a different way of applying it but it isn't remote phosphor.
Cree's datasheet does not have the word "remote" on it. Just did a quick search and didn't find it. It might be on a picture, but I don't think so.
I think at this close range, the LED is probably most similar to a traditional LED then a remote phosphor device (from the limited experience that I have at least).
