belomeclone
- Joined
- Oct 13, 2009
- Messages
- 212
I was told they would be released yesterday, but I cannot find them anywhere. I have buying plans for these and this lack of information is only helping my wallet.
Danielight said:I've been waiting for EagleTac to come out with the clicky model so that I can swap the head from my D25LC2 twisty to a clicky body tube. I hope they are planning to make just the clicky body available.
If the pricing is really good, then I'll consider getting the whole light. When I first began to inquire about the availablility of just the clicky body itself, I was told it might only be about $10. Since I have bought two other flashlights since then, I'm thinking I might do well to keep my next purchase price on the low side.Nope.... Just buy a new clicky's model the pricing is still going to be really good!
Wow. You just helped my wallet. I was literally just about to purchase a D25C.
I really can't decide what I want right now, except I want something to replace my currently MIA Neutral-white Quark MiNi AA.
It's not, you have Turbo with head tightened. Heat isn't an issue because it has stepdown after 3 minutes.[speaking of which, why is the turbo mode with the head loosened? Ideally you'd have better head conduction with the head tightened. Your going to need it for the big time turbo lumen numbers]
Simplier explanation - you can choose how bright last two (the dimmest) modes can be. For example in D25A with XM-L you can choode between 176/107/10/1 and 176/107/20/4lm modes.The moon mode needs clarification. Are you locked out of the high mode when you elect to use the moon mode function? or does Eagletac just rename high mode as 'medium'? Also the explanation of outputs of the 1st & 2nd cycling modes change dependent if you are not in moon. One says the lowest output increases 6x, and the 2nd lowest output increases by 2.5x.
and the prices look about 50% greater than the twisties.
Looks like that's true on the two-cell models. The single-cell models still have the nicer pocket clips screwed to the top of the tail. My guess regarding the pocket clip placement on the two-cell models is that the clicky switch may add enough length to the light to make it a little too long for deep-pocket carry if the clip is way at the top. (BTW, the clip on the two-cell models looks a lot like the clip in my Quark AA2, which is good & solid because it is held in place in the joint between the center and tail pieces.)I was really looking forward to the D25LC2 (18650) Clicky in neutral, now I see they changed the pocket clip so it's no longer screwed on like the non-clicky version and is lower on the body. What a bummer.
Looks like running XML D25A & D25C on Li-ions is direct drive only... you'll lose the other lower lumen modes. 🙁
