Anybody ever use this in a Fenix?
amanichen
Virginia
I did a search and it only came up with one other thread, but I'm wondering if anybody has any experience with this reflector:
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=3317
The situation is that I have a L2P with a SSC P4 in it, and I'm trying to make the spillbeam tighter, and/or increase the throw. The dimensions and thread appear to be compatible with a Fenix head. But, the big unknowns are if it will actually fit, and if the geometry and texture will provide a narrower beam than with the stock reflector.
I tryed it in civictor, or in L1S, don't remember which.
It didn't work first because it shorted led's positive contact, so it needed some dremel, the walls are thicker than original.
Beam was wider. I may try it with L1S which has P4 USVOH now.
So it does fit with little work but beam is wider.
Juha
