MikeF
I have one of these IDX X3-Lites ordered, and it should be in by the end of the month. It will be powered from the power tap on my Sony Camcorder, that uses two IDX Li-Ion 14.4V 55Wh/3.8AH NP style batteries. It is equipped with a dimmer also.
IDX X3 on camera video light
They are claiming that the output is approximately equal to a 35w lamp at "Daylight" color temperature, while drawing only 11 watts from the battery. There are no specs as far as LED source, possibly 4-3 watt luxeons under-driven, or 3-3 watt Luxeons over-driven? Or maybe 2-5 watt luxeons slightly over-driven? Only time will tell.
One 35watt bulb that is used for an on-camera light for video production is the FMW-MR16, 12V 40 degree flood beam, rated at 1000 center beam candlepower, and 550 forward lumens at 3,000 degrees kelvin. So 11 watts of LED producing 550 lumens seems outstanding. There are also MR-16 35w spotlights with 9 degree beam angles that are rated 12,500cp, and 575 lumens.
