Anyone successfully take apart a SFP60L?
Beastmaster
Phoenix, AZ
Just wondering. I'm trying to take apart a SF P60L LED Lamp assembly and I'm stuck - I can't seem to separate the reflector from the rest of the assembly.
TIA,
Steve
I bet. The reflector is joined to the plastic portion with two rivets. They are visible from under the spings if you look carefully. It require some careful drill works...
I plan to put a SOB1000 in the P60L to make my own P61L.
Regards
Anthony
Regards
Anthony
Well, I'm trying to take a P60L apart to see if I can make a X80 mod.
-Steve
Steve, search for posts by Will Abbot - he posted pics a while back.
I know there was someone who did to a mod using an X80 reflector and some other stuff. I want to use an X80 reflector and a P60L LED module because the spring/contact setups work already with the 8X/8NX/8AX series with zero mods.
I may have to cut the reflector down a bit.
