Anyone want to help someone new at this?
K A
Kansas
Would anyone like to take a stab at this?
I scavanged some LED's from work off some old displays that were going to be trashed. My thinking that I could use the LED's for other projects. My problem now is trying to figure how the correct values for the LED's so I don't fry them.
Pictures of said displays
Display #1 runs off 2 AA batteries and has 2 clear lens red LED's. It uses something to get the LED's to flip flop at a constant rate. It has 1 resistor and if my eyes don't deceive me the colors are " Blue Grey Yellow Gold " I assume a yellow color. It blends in well.. its really hard to tell.
Taking a Multimeter and testing the pos/neg across a led and I get a max of .60 volts on either LED. This seems rather small? Testing the pos on the LED and the neg on the battery case I get 2.10 volts.
Display #2 runs off 3 AA batteries and has 6 clear lens LEDs (3 green and 3 red). This one again has something to make the LED's look like they are chasing each other. Though how this is wired up makes my head hurt.
lambda
Iowa
K A,
I would think the 2.10 volts you measured to about right for the red LEDs. The green ones are probably closer to 3.2V.
lux0
A Vf of 1.6V for red and 1.8V for the green is typical, depending on the current through them.
