D
djpark
This posting is related to my previous posting "ARC-AAA with 8mm white led".
I didn't realize that my ARC-AAA-8mm was first, so I didn't mind being the first again with ARC-AA-8mm. /ubbthreads/images/graemlins/grinser2.gif So here is my experience to bring ARC-AA with 8mm white led from ISP.
First, I started with preparing the heads.
The first ARC-AAA-8mm at left is put to rest by taking the heart (Micro Converter) out of it and now it is in ARC-AA-8mm.
The crimp of ARC-AA is really short and tight compared to AAA and I had to virtually break it off. Pulling the led and circuit assembly from AA head was not that difficult. I read a thread recommending the oven, LMASAP mentioned liquified nitrogen. But I put it in the boiling water through indirect heat transfer via water. When the epoxy was a little softer, lift the board from behind through two holes a little, then push the led from the front. Anybody can guess if it is still working?
I used 7mm (the biggest I had) drill bit to make the main hole, but the widening another 1mm was really painful process. It would be better to start with 8mm drill bit.
AA head is a lot deeper than AAA head and led can hide within the reflector without jutting out like AAA. Also I had luxury to adjust the height of led since there were more room within the head (same diameter but deeper). Now I get to see some light bounced back from the reflector.
AA head in the pic above is already completed set together with other blank AAA-8mm heads, below is bottom view with Micro Converter in it. MC is attached with a 1/4 round wire along the edge to make it a tight fit and also to be ground connection.
I didn't crimp it since I know that I will never be satisfied with what I have and later try to improve the circuit. The original battery retainer ring in the pic is not fiting well, I find that AAA retainer fits better.
Blow and suck test reveals that it is not waterproof (due to irregular round of the hole, try 8mm drill bit to get better fit). But when put into the casing with o-ring, I can hardly suck air from it. So can I say "water-resistant"? /ubbthreads/images/graemlins/blush.gif
Put it into the tube with the battery and behold, "Thy light hast come!".
Beamshot at 1m from the wall. Left is a standard ARC-AAA-P, right is ARC-AA-8mm.
Beamshot at 2m from the wall. Left is a standard ARC-AAA-P, right is ARC-AA-8mm. I may have accidently touch the AAA-P to point towards right, so the beam could have been swallowed by AA-8mm.
This time, I am using a new led but I didn't measure the current flow to led, even I did, the value wouldn't be accurate. The current draw from a fresh AA is 0.36A (tested with 5 batteries with the same result).
Now I have a lux meter and this is the meter reading at the brightest spot.
<font class="small">Code:</font><hr /><pre>
Model / Distance 0.5m 1m 2m 3m
ARC-AA-8mm/ISP 116 32 9 5
ARC-AAA-P 49 13 4 2
ARC-AAA-S 64 20 5 3
ARC-AAA-5mm/ISP 85 24 7 4
</pre><hr />
Yes, my AAA-S is a lot brighter than AAA-P, even other AAA-S in my possession are also brighter. But the real gem is 5mm white from ISP.
-- DJP
ARC-AAA-P 49 13 4 2
ARC-AAA-S 64 20 5 3
</pre><hr />
-- DJP
