Arc AAA Clip
Nathan S
Italy
I haven't seen any threads on this, so I'll ask: is the clip on the new Arc AAA removable?
Thanks.
I was concerned it would scratch or slide so I put a 1/2" length of shrink tubing on first then used needle nose pliers to splay the clip collar wide enough to go over the tubing. I also put a 1/4" length on the tail end so I can bite down on it, rather than the HA. (ouch!)
It does take a little finish off the knurling if you're not careful. It did on mine. Now I spread the clip a little with my fingers before sliding it on.
We put quite a few of these on each day and they don't scratch the housing. You need to be careful of course. I recommend you slide it from the front end.
Peter
