just received the arc aaa le in mail today and found it to be everything forum members said it would be. but of coarse anything can be modified so here is my quick mod. i took a 12mm inside dimension plastic "cap plug" routed it out to 10mm and installed a 3x enlarging camera lens that is also 12mm wide. there is enough inside lip to keep the lens secure against the arc head. and the cap slides over the head for a tight fit. the first thing i noticed was how it turned the bluish tint of the arc and made it almost a true white. some kind of a prism effect i guess. because of the magnification it takes the useable light and concentrates it to more of a very bright spot with not as much flood. check it out at www.geocities.com/dangee111 takes a few seconds to load
