chimo
After getting some 26K mcd white LEDs I decided to give modding my Arc AAA Turquoise a try. The Turquoise was bright but it had a lot of beam rings and the LED was scuffed up. By far, the hardest part of this mod was unpotting the head. The rest was a piece of cake.
I started by carefully uncrimping the head. Next I heated up the head and pushed out the "plug" by pushing on the LED with a wooden dowel. With a little effort the whole plug slid out.
I used heat and a small pick to flake off the softened epoxy. This was an iterative thing - heat, pick off epoxy and repeat until it was all gone.
When I got enough epoxy off, I heated the legs of the LED from the battery side of the board and wiggled out the LED and capacitor soldered to it. I was careful not to bend the LED legs out of shape. I unsoldered the capacitor from the LED and removed the remaining epoxy from the board.
Next I bent and trimmed the legs of a new 26K LED to match the one I took out. I soldered the LED/cap assembly on the board and tested it. It worked fine, so I re-assembled the head. I didn't re-pot the head (just in case some 50K mcd become available). All went well and here are the results.
The unpotted circuit board.
Assembly with the new LED in place.
Cree UV @ 100mA no reflector/optics
Arc AAA w/ 26K mcd
Q3 w/ TW0J
MiniProIII w/ TW0J
Paul
Arc AAA w/ 26K mcd
Q3 w/ TW0J
MiniProIII w/ TW0J
Paul
