Craig, one of these days a jumbo jet is going to mistake you for an airport beacon and then who will update your site?
I was playing with the Arc-LS again tonight. Using it to read street signs from my car (a common task for the light in my car).
This Friday we hope to lock in the housing design for the Arc-LS and start programming the CNC machines. Still a few design kinks to work out. We need to get these solved if we are going to ship by the end of the month! It's going to be close.
Looking over Craig's list of recomendations on his website, I am not sure we will be able to address every one of them right off. We should get most of them though.
So far it looks like we have solved the beam focus/alignment fairly well. The no-roll feature will have to be part of future power pack designs (it would add too much to the head bulk if we put it there instead). Still working on improving water tightness- this is a tough one. Battery rattle is still being worked on.
Probally the toughest compromise is going to be the lens protection. The stock lens is optomized for optical performance and not strength. It can be scratched. But, using other optics or placing another lens (for protection) in front of it would make the light slightly dimmer plus add bulk and cost. With the prototypes, we opted to recess the lens deeply to protect from sharp pointy things. In normal use, it shouldn't get scratched. I haven't damaged my prototype's lens yet and I routinely carry it in my pocket with my cell phone. How about you Craig and Brock, any scratched lenses yet?
We may find that the lens just doesn't make it in normal use. What we will do is either recess them further, make custom lenses, or add an extra lens (acrylic, etc). Please be aware that adding a second lens may sound cool, but it will reduce output by as much as 10 percent.
Finally, we already plan on using gloves to install the optics and we already plan on locking up the rear threads.
Chris's prototype will be sent off after we solve some of the water sealing problems.
Peter Gransee
