I'm not a big fan of cr123a's. I tend to think of them as too short and fat, and not having flexible enough recharging options.
One big limitations of the 123a battery is the lack of good rechargables. 16340's are a waste of .3-.7 volts and have short runtimes. 18500's don't fit in quite right, and only work well in seperate bodies or in lights designed for two or more cr123a's. In contrast, the AA cell has well-established rechargable options in the form of the NiMH, and precharged NiMH batteries, which offer decent power selections.
Also, AA size has the "overdrive" option of 14500 batteries, with less amps than a NiMH, but three times the voltage, and overall more milli-watt hours than your average NiMH (3240 milliwatt-hours for a 14500 at 3.6v, and 3000 milliwatt-hours for a 2500mah NiMH at 1.2v)
Another big limitation of Cr123a's is the price. A CR123A costs about $1.50 online and around $5.00 in a retail store.
A AA costs about $.50 retail or $.30 online, or about $1.00 in a 4-pack retail. And a NiMH AA costs about $4.00, with a charger going for about $15-30. So AA's are much cheaper.
Finally, AA's can be picked anywhere. A CR123A cannot be.
So what are the CR123A's advantages? It can power very bright flashlights from a very small size. It doesn't really last a long time, not much better than an NiMH AA on a medium-bright flashlight, but it does last really long compared to AA on super-bright lights. It provides insane voltages in small sizes, e.g. 6 volts from just two batteries, and it is a little bit shorter than a AA, but fatter as well.
A myth is that CR123A batteries last longer than AA's. Not necessairly. A brand-new 2650Mah NiMH has nearly as much power as a 3.0v 900Mah Cr123a, and performs similarily in relatively high drain situations. In situations where extreme voltage ramp-up is needed, such as very bright flashlights, CR123A performs better, likely due to the high initial voltage.
Overall, I'd say the rise of the LED, which runs great from just one AA, is really helping to bring down Cr123A's. And that's a good thing. I'd like the flashlight community to use the batteries that everyone else uses.
