Are there any headlamps which use 18650 batteries...
scsiguru
...that don't have the strap that goes across the top of the head?
With Zebralight or Armytek it is optional, you can choose not to mount it.
I have never used the upper strap on my Zebralight and Wizard Headlamp
Thanks for the info on those two brands. I've always liked the Fenix line of flashlights. I'll have to see if theirs are the same.
+1
maybe olight as well?
i know they make headlamps idk if they have the top strap
if so i believe its optional
You are not obliged to use a specific band.
Look at the diameter of the lights that interest you.
I use a Zebralight headband on an Armytek Wizard Pro.
but I could also do the opposite.
There are the Led Lenser MH10 and H8R. These are both rechargeable vis a USB socket, so you don't need to take the batteries out for recharging.
Unless you need to jeep working while the battery charges
Sent from my iPhone using Tapatalk
This is true. It's supposed to last 5h on 600lm or 10h on 250lm. I recently replaced the heater matrix on my SAAB 9000 in the dark and 600lm was too bright and I used the 250lm setting. The other alternative is to have a replacement battery ready charged. The battery holder is a 1/8th turn quick release. That way you would get 10h on 600lm and 20h on 250lm.
Of course, you could always charge it while wearing it with the cable attached to a PSU (the phone type battery back-up ones) in your pocket. Also to answer the OP's second question: These 2 models don't have the strap on the top of the head.
If you're partial to Fenix lights then you can check out these options that allow you to choose if you wanna run the top strap or not.
Just release a month ago. https://www.fenixlighting.com/product/fenix-hm61r-multi-use-headlamp/
https://www.fenixlighting.com/product/fenix-hm65-rechargeable-headlamp/
https://www.fenixlighting.com/product/fenix-hl60r-rechargeable-headlamp/
https://www.fenixlighting.com/product/hl55-fenix-headlamp/
Good luck with your decision.:thumbsup:
