Are these batteries any good?
Welcome to CPF, OKgetdown.
The link you have given in your post is not working. If you give the make and description of the batteries, I'm sure someone here will be able to help you.
Woops. There. It should work now.:twothumbs
:welcome:
In the sticky at the top of this sub-forum (threads of interest) is a link to the 123 shootout.
There is information on those cells in there.
Welcome aboard from a fellow Oklahoman.
Many have mixed feelings about those batteries due to the volatility of CR123As in general and reports of other non-USA-made batteries venting.
As a general rule, if you are at all concerned about the safety of your cells, then it wouldn't hurt to stick with USA-made cells like Surefire, Duracell, Energizer, Rayovac, Streamlight, Battery Station, et al. Especially in lights that use multiple cells in series.
Having said that, I have used a few Titanium cells myself and feel pretty good about them. Unlike low quality cells, they feature a mechanical PTC that makes them safer and as far as capacity goes they are very close to the USA-made brands.
So it's completely up to you to make the judgement call on whether they are safe enough for you to keep around. But as long as you follow accepted care and usage of CR123A primaries, the likelihood of Bad Things happening is low.
Please be familiar with the information in the first post of this thread (or at least the first section) before using Lithium primaries: http://www.candlepowerforums.com/vb/showthread.php?t=124776
