I recently added some 14500 batteries to my last order from sofirn despite not actually owning a torch that used them.
so as you do I have now just ordered a torch that uses them (lumentop FWAA). But have since read that you must use unprotected batteries with said torch. So now fear the batteries I have will be no use and am now concerned that if I did buy unprotected batteries it will result in the burning down of my house.
so
1 are these batteries protected?
and
2 is using unprotected cells as risky as the name "unprotected" suggests?
thanks in advance.
so
4pcs 14500 Batteries 900mAh
Notice:Some batteries will have a low capacity when they are used for the first time after receiving them. For this situation, please charge the battery 3-4 times and then re-test the battery capacity.Item DescriptionCell Type: Li-ionBattery type : 14500Minimum Capacity : 700 mAhVoltage...
www.sofirnlight.com
and
thanks in advance.
