KT, Brightnorm and SP
I now have both, Triad I and II. I bought the used TRIAD I from the owner of Magnum Enforcement. It is a beautiful silver color one, internal focus of course.
They both focus to about the same small spot depen upon the bulb it has. There are different kind of bulbs and the filament construction may vary.
Now the difference is that the type I housing surround the base of the bulb including the rubber cusion very securely. While the type II, the bulb merely insert in the socket which can be wiggling loose thus may cause the bulb not positioned in the center which require a good eye to correct it.
The remedy to the type II is to bent the pin of the bulb zig-zag shape to increase the drag when inserting into the socket. This way when you swing the lite the bulb won't come out. Be sure to use two small needle nose plyers or you could ruin the bulb.
One last suggestion for the potential ASP buyers: make sure you ask the supplir to get you the TYPE I internal focus. The owner of Magnum Enforcement told me some supplier still have some TYPE I available. So hurry up before they run out.
If you do get the TYPE II, they are as good as TYPE I with the technic discribed above.
I am happy whenever I get a chance to go out at night shining the lights to the sky or trees. I see two beams reaching out far away even with the bright street lamps on.
If you want a good close up light with good beam, use Luseon Star LED. Waiting to mod the 5W LS to my 3D MAG. That sure will help me see a LOT farther. Lets be patient.
Henry
