<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jinng:
Yes, batteries are new.
I have checked the switch as you suggested and it looks to be in good working order.
How do I check that the spring is properly/correctly aligned ? The spring looks to be fine; not bent, twisted or anything like that.<HR></BLOCKQUOTE>
Jinng,
I don't know if this help, give it a try.
If you have a meter, switch to continuity mode. With one probe touching the spring and the other to the edge where touches the body when screwed in.
If no beep sound in the digital meter or showing o ohm in analog meter, push the switch button and try again. If shows no continuity then something wrong with the switch I would guess.Good luck.
Henry
