--Oops, maybe I should have posted this in Homemade and Modified? Sorry.
I need to put together a light for my bike.
I want to build it myself--because that's more fun than buying one.
I need to assemble it as inexpensively as possible (I don't have tons of cash for this), but I want to use quality components and end up with something I feel good about.
I'll be using the light to commute on country roads--about a 35-40 minute ride twice a day, and I need to be able to see with this light--not only "be seen." That said, I don't think it needs to be super bright--just good enough for bicycle speeds.
Currently I'm planning to run 2 Lux 3 stars behind 20mm optics. I'm thinking about using one oval beam optic for side fill and one tight spot optic for forward illumination--but I really like the ability to swap around 20mm optics or reflectors to achieve the best light for my use.
I plan to use a NiMH battery back in a water bottle--at least initially. I want to use a driver that will give me some flexibility on input voltage so I can switch battery packs or move to a dynamo later.
This is my first LED build, and I need some advice from you guys, if you'd be so kind:
1. What should I use for a housing? Is there a cheap light I can buy and canibalize? Or should I build something out of aluminum tubing or something?
2. What should I use for a driver? I've looked at the "pucks" from LEDSupply, but I am not sure what I need. I'd love something pre-made and easy to hook up--ie. if I can just wire a box to my stars that will give m elots of flexibility with mounting and housing (over a driver that's jsut a PCB)--right?
Any other advice you guys can give me would be great! Am I way off with what I'm planning? Will this make a useble light?
