nnamssorxela
- Joined
- Nov 29, 2012
- Messages
- 10
Hello,
I've stumbled across this forum many times throughout my search for everything LED related, and I figured it was finally time to man up and post a "couple" questions. I will be the first to tell you that I know next to nothing about LEDs, resistors, and heat sinks, but I'm willing to learn! Please bear with me as I attempt to get everything from my head into type.
First off, I'm trying to make some LED turn signals for my motorcycle for both legal and visibility reasons. I've purchased some cheap LED signals before, and in the day time you just can't see them well enough. "Quality" LED turn signals are in excess of $100 so that wasn't an option either. I finally decided that the only solution was to make my own signals. I jumped on Ebay and bought some 12,000mcd "superflux" LEDs (pictured below), but to my disappointment, they weren't much brighter than the cheapo LED signals I had purchased previously.
See Rule #3 Do not Hot Link images. Please host on an image site, Imageshack or similar and repost – Thanks Norm
I gave up for the time being but eventually came across this guy who made some single LED signals using some .5w "strawhat" LEDs that are ~95,000mcd. In the video they appear bright, but it was reported that they were "less impressive" in broad day light.
This got me wanting to make some signals again. I found some 1w strawhat LEDs that claim ~190,000mcd and I think that they will do the trick. This is a link to the ebay page.
Now here's where my questions start rolling in....
The resistor calculator I use says that the power dissipated in my resistors is a concern (~2970 mW). I planned to the LEDs from the link above with a single 33ohm resistor (calculated using 12v source, 2.1v forward voltage, 300ma forward current, and 1 LED in the array). If I use 5 of those LEDs I do not get the power dissipation warning, however my roommate seems to think that I will need a heat sink just for the 1 LED, not to mention using 5. He also mentioned using something to drop the voltage, then using resistors from there.
Would several resistors in series spread the load out so power dissipation is no longer a concern?
Is heat really an issue with LEDs like this? Especially when using for such short intervals like turn signals?
If I use just one led per signal, it will be exposed like the one in the video (potentially lots of airflow?) but if I use 5 LEDs, I will probably gut some of the cheap signals I have and put the LEDs in the housing.
Are there better options than what I'm looking at? Any advice is appreciated.
-Alex
-Alex
