aw 18650's not charging in ultrafire charger-help.
willrx
Atlanta, Ga
Help. Just received 2 aw 18650's and an ultrafire charger and it looks as if the pos end is not making contact. What to do? Thanks.
willrx,
The new version WF-139 charger has a raised +ve contact and the previous version has a flat +ve contact but these has been modded with solder bubs from me. If you got the charger from other parties, you'll have to add solder bubs to the +ve charging contacts for use with flat top cells.
AW
AW,
Thanks. I received my order from Lighthound who I think is great. Spoke with rep on phone and she is sending the new version you mentioned. Bad thing is, now I have to wait even longer to use your batteries. Honest mistake, I'm sure. Anything I can do in the meantime?
If your charger is like the one on left, a small wad of alum. foil will bridge the charging contact and battery.
AW
3.9V is about 45% charged. They came out the factory this way - best for storage.
The red LEDs will blink every few seconds when the Samsung IC checks the feedback voltage from the battery. In fact, it 'll check the feedback 3 times during every blink. It is the designed charging parameters of the charger and is perfectly normal.
