Ok, Ive been using the original AW c-cells in my light to power a wa1111 bulb, this setup has worked flawlessly for about 1 1/2 years as my primary duty light, probably have 150ish cycles on the batteries on a wf139 charger. recently I noticed that after about 50 seconds the light turns off. The batts read 3.88v. when I turn it back on, it turns off again about 20 seconds later, turn it off and on again, 15 seconds later it turns off again. The batteries cant be that depleted can they? they still read over 3.8 volts, and when I charge them they're almost usually around 4.17-4.19. I'm stumped. Up until now theyve worked flawlesly, any ideas, suggestions?
