Here is the best deal I have found on enough Deoxit for you and a friend to last for many years. Use it to clean oxidation that forms on many types of metal surfaces wherever an electrical contact is formed.
You can remove the spring to get down to the upper switch contact. Then also hit the spring and cup that contacts the bulb base. Apply it to the bulb contact, the battery anode (+) contact, and why not the battery contacts too? Then there is the top of the tailcap spring and the bottom. But why stop there? You can then get out the soldering iron and add 'jumpers' to reduce both the length and resistivity of the conducting paths. Google search on 'resistance fix' for related threads with pics and instructions on how to reduce resistance further in the switch and tailcap.
