kicken_bright
I own a fenix p2d and I use aw protected rcr123 cells. Would I be able to use unprotected IMR cells as well, or would the lack of protection possibly fry my p2d? What do yall think? should I take the risk?
Have you tried AW's LifePo4? I have been using LiFePo4 for over a year in my P1D Q5 and love it. Slightly less capacity than the IMR (LiFePo4 rated at 500Mah @ 3.2V ) but you get all your modes and probably safer with the voltage being very close to a Lithium primary.
hmm... correct me if i'm wrong... but i thought the IMR cells are just a lil less capacity as the AW protected ones...
The P2D is known to lose the current-regulated low modes at 3,7 V (all modes will be the same) so I assume it's DD with IMR123 cells as well as regular RCR123Assuming your light is regulated [in the case of the P2D, it is] and not direct drive, theres going to be a middle man between your LED and the battery. The driver should only draw the current it needed for operation and not more, so chances are you are only going to notice a shorter runtime.
now if your light is DD that may be a whole other issue
hmm... correct me if i'm wrong... but i thought the IMR cells are just a lil less capacity as the AW protected ones... BUT... at continuous high current draws, will actually last longer than the protected higher capacity ones...
also... at the low side of the current draw... you actually get even less runtime as IMR's aren't geared towards low current draw applications...
KraZy
my point is that in DD the LED will see more current if you use IMR cells, and the heat might become a problem
