Actually Paul our 10180 cells come from AW. Some of the 10180 cells do come in a bit short & we have had to make a small adjustment to new Wee's going out.
There is a tiny 0.5mm thick magnet available (I got some from AW) That provide a fix for this. Best to stick the magnet to the negative end, the insulation rap stops from moving about for a potential short which would make come on.
Another option would be to float a small amount of solder onto the positive copper disc on the LE. I hope you find a good solution.
Never had an issue with the cells provided by Rob
Could anyone provide a side by side photo comparison of the two batteries?
Tnx...
There are no worries at all with the nano CR123 charger we supply. When measured the max current seen to the 10180 cell is no more than 100Ma which quickly drops as the cell begins to charge.
These have been used for years & no reports of any mishaps what so ever.
