TriChrome
This is my first post, but I've been reading/researching for about two weeks now and think I've picked out the correct batteries; but I would still like a second opinion to make sure I'm getting the best combination of lumens and run time for my two lights.
My first light is a Surefire 6P with a Detonator +1 cell extender (3x CR123's/9 volts). I'm currently running a P91 bulb which give me 200 lumens for 20 minutes.
I'm looking at getting 2x 17500 Protected cells (with a 1.6mm spacer):
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=1299
To run a Lumens Factory HO-9 320 lumen bulb. I was told this would give me about 40 minutes of runtime on the above batteries. Is there any better combination? And am I really going to get 40 minutes of runtime?
___________________________
The second light is a G&P (Surefire 6P clone) with a CREE LED (3.7v to 9v) bulb with G&P A.I. Strobe tailcap. I want to convert this to rechargeables using 2x R123 protected cells:
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2190
I was told this would give me about 80 lumens for 90 minutes. Again, any better setup for something like this?
I'll be using an Ultrafire Multi-Battery Charger for both sets of batteries.
Thank you for any advice.
