Battery "cleaning"??!!
IMA SOL MAN
The HEART of the USA.
Picked up some silicone spray this morning,, wasn't expensive.
I'll try using it to clean battery contacts & as a lube, good to have around anyway.
Silicone is dielectric
product info: Keeps battery terminals and cases clean, minimizes corrosion,
prolongs battery life. A good electrical insulator that helps
prevent electrical losses. Works well to weather proof
ignition systems, plus insulators and distributor caps.
Improves radio reception, lubricates antennas,
Noooooooooo! Insulator!
orbital
WI
Yep insulator, your right.
I'll just keep it anyway. Silicone doesn't wreck o-rings etc..
LuxLuthor
MS
I start with Deoxit (if not also needed to remove gross amount of corrosion with sandpaper/emory board), and finish with Deoxit Gold
