3D's DD seems to be a good combo, as I would imagine 3C's would also be.
My 3D TWAK DD is awesome! With fresh batteries, I measured 3.8v at the LS and it was pulling 1.8A!!! /ubbthreads/images/graemlins/eek.gif That's nearly 7 Watts! /ubbthreads/images/graemlins/ooo.gif This didn't last for too long though. After about 10 minutes, it was down to 3.7v and 1.4A (5.2 Watts).
Now that the batteries have a bit more time on them (probably about an hour and a half), things have settled into a more reasonable level. 3.6v at the LS and 1.2A draw (4.3 Watts). Still awesome! I don't think that this combo should really do too much harm to the LS, as the Vf doesn't go much above what it should on fresh batts.
BTW, to make the battery capacities clearer, here is what is listed at
data.energizer.com for standard alkaline batts:
D --- 18,000mAh
C ---- 8,350mAh
AA --- 2,850mAh
AAA -- 1,250mAh
These need to be taken with a grain of salt however, as all of these are quoted down to a cut-off voltage of 0.8v with only small continuous current draw (25mA). For higher current draws, say at 1A (like we do things), things are a bit different (based off of my interpolation of the graphs):
D --- 7,000mAh (appx) - 39% of quoted capacity
C --- 2,300mAh (appx) - 28% of quoted capacity
AA -- 1,200mAh (appx) - 42% of quoted capacity
AAA --- 300mAh (appx) - 24% of quoted capacity
and quoted for the popular lithiums:
123 (3volt) - 1,300mAh (with 100 Ohm load to 2.0v)
L91 (1.5volt) - 2,900mAh (Lithium AA, rated at 200mA draw to 1.0v)
but at say 1A draw (again from the graphs):
123 - 850mAh to 2.0v - 65% of quoted capacity
L91 - about 2,600mAh to 1.0v - 90% of quoted capacity (I believe this is a bit too high)
So there you have it. I hope this makes things a bit clearer for some. This is all quoted for continuous operation, so battery resting periods aren't taken into account. As we all know, if you allow the batts. some time to rest, they recover some lost voltage. For real-world mAh ratings the way we do things, I would speculate they're nearer the 1A capacities, but maybe 25%-30% better. /ubbthreads/images/graemlins/icon3.gif
Disclaimer: YMMV /ubbthreads/images/graemlins/yellowlaugh.gif
***edit***
Edited to say I based my info off of my interpolation of the energizer graphs.
