troller_cpf
- Joined
- Jun 7, 2009
- Messages
- 249
Hi guys,
I'm going to build/mod an old spotlight with the Osram HLX64663 36V 400W halogen bulb, and I've got to build the battery pack, as the standard SLA battery cannot be used for obvious reasons.
My idea is to put 10 Li-Ion 18650 (3000mAh) in series so to obtain a nominal voltage of 37V and 3000mAh.
In this configuration I should get 16 minutes of light (on paper).
Question is: the Osram lamp, being a 36V, should require 400/36= 11 Amps, and m battery pack is only delivering 3 Ah.
Is it ok anyway? I mean, will the bulb light up at full power? I have a doubt about this but then I look at the Mag623 wich has a 12V 100W bulb = 8 Amps required to the bulb and the classic battery pack used is just 1.4 Ah, and it works perfectly.
Following that "math logic" in the Mag623 the battery pack has an equivalent of 0.175 times the amp to the bulb, and in what I'd do my battery pack would have an equivalent of 0.27 times the amp to the bulb, so it should work fine by logic.
any comments?
thanks everybody!
any comments?
thanks everybody!
