BatteryCharger
As some of you saw in a previous thread I happen to have an enourmous amount of AA batteries. Many of them will be made into 18v battery packs, and I'll probably need to weld tabs on them to do that. I don't want to try to solder them, I'll just end up cooking them...
First of all I understand how "normal" welding works. I have, in the past, used three car batteries hooked in series to arc weld 1/4" steel plate. I have also seen some DIY battery tab welders that seem to all use capacitors charged up to 25v or so discharged through copper electrodes.
I don't have any capacitors and don't want to buy enough to build a welder. Couldn't I acomplish the same thing with 2 or 3 car batteries the same way I can weld steel with it? Basically we're just talking about a quick, high amperage, ~25v or so "jolt" through 2 electrodes, right? Car batteries will easily give a few hundred amps...
