Battery Testers?
357
usa
Was wondering if they make a battery tester that will test for 1.5 volt alkalines, 9-volt alkalines, AND 3-volt 123 batteries. Any such tester out there?
If so, which one does you recommend?
My dad has one he got from radio shack.... not sure it is good though. Trying to figure out the capacity of a AA and D cell using the same load doesn't always work too well but most testers do it that way. You could always get a DMM and a resistor for each size battery and make your own test.
[ QUOTE ]
javafool said:
I have a ZTS MBT-1 that I bought from ContactEast and am quite satisfied. It is a little steep at $60.25 though.
http://www.contacteast.com/product/group.asp?parent_id=8622
[/ QUOTE ]
This one looks real good to me and I've been considering getting it for months. It tests the battery under load and shows the battery's remaining power capacity.
They make a "smaller and less expensive" one as well ($30).
I ended up getting the ZTS Mini-Multi tester. I love it. For the batteries I use (Alkalines and 123s) it does everything I want it to do. Thanks so much all for the recommendations.
I've had a ZTS Multi Tester for a couple of years now, and I love it. I use mine all the time, and consider it money well spent.
Peter
