BatteryStation brand lithium AAs ?
David_Campen
California
I see that BatteryStation lists their brand of lithium AAs as if they are now available for purchase. Has anyone bought any of these? Anyone seen any discharge curves for these?
rdshores
Vermont
David_Campem said; [ QUOTE ]
Quote:
Flash Amp'd one at 7.1.
What does this mean?
[/ QUOTE ]
It means you put your multimeter on the 20amp scale and momentarily short across the battery for a current reading.
David_Campen
California
Anyone know what the chemistry of these batteries is? I thought that Eveready/Energizer had the Li/FeS2 battery chemistry all to themselves via patents.
Lurveleven
Bergen, Norway
Contact Silverfox to get these cells tested. If you send him some batteries to test, then he can include the results in his battery shoot outs as well.
Sigbjoern
voodoogreg
Global
I got two, to try.great meter out at 1.8V and change.
they the "tit" + end look's like a L91 enegizer, but they usually read 1.7 and change. seem to be well made only problem is I'm using one in a ultra G and even with a carbon zinc those light's run forever!
Anything like his 123's it's bang'in. VDG
PhotonBoy
Annapolis Valley, Nova Scotia, Canada http://tinyu
[ QUOTE ]
[/ QUOTE ]
Has anyone looked carefully at the cells' end caps and case to check if they're physically identical to Energizer cells? Are these re-branded Energizers or an Asian-produced knock-off? Just wondering....
[Edit] Oh, it would be nice to know what the voltage is on a fresh cell.
Sway
North Carolina
[ QUOTE ]
[/ QUOTE ]
I just check 10 BatteryStation AA lithium cells throwing out the highest 1.92V and the lowest 1.82V they average 1.84V. The end caps look a little different than the Energizer L91.
Later
Kelly
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
Here's the L91 and the Battery Station AA's side-by-side:
Here are runtime plots on the XM-3 using two L91's and 2 Battery Station AA Lithiums. On average, the Battery Station Lithiums generated about 84 Fc@1Ft more light than did the L91's (measured at two hours into the plots).
