wintermute
- Joined
- Nov 16, 2004
- Messages
- 681
A normal Leadlight has a beam divergence of <1.2 mrad correct?
Well someone I know got a laser pointer which tested at 54.3mW using the green LED method. Here's the thing, at 3m the divergence is 14mm, and at 6m the divergence is 28mm. If you extrapolate these numbers to 10m it would test 46-47mm, so 4.6 mrad or so. Does this seem a little excessive to anyone else?
So assuming that the collimating lenses aren't in a good position, and the fact that they don't want to take apart their 1 day old $330 pointer, they go to the vendor. The vendor responds:
"Our units are not the same as before and I do think the specs listed in the products are incorrect for divergance. We had to increase the divergence slightly to make this laser less viable for airplane targeting. The difference will not be noticable in regular use."
Does this sound flaky to anyone else. 4.6 mrad seems quite excessive to just reduce the usefullness to "lase airplanes", I think that the vendor's response is more likely a very poor excuse for a bad pointer, or worse yet a bad trend for a whole new series of pointers.
What do all of you think? /ubbthreads/images/graemlins/confused.gif
P.S. bootleg2go, if you want to copy your reply here, please don't hesitate.
