I thank you. I will watch it. But I have watched so many pictures ... about many flashlights but the reality is very different from the pictures and I'm afraid to make a mistake in buying it.
One pratfall you can take when asking what light to get is that, on average, everyone just tells you to get what THEY got.
Part is because they know THEY like it, and, they typically have no idea what YOU would like.
ADD to the above that YOU have no CLUE what you REALLY want. Your posts are all over the map. How can a stranger GUESS what YOU want, when YOU don't even know?
How can anyone KNOW when the "Right Answer" has BEEN reached?
Really, you NEED to imagine the light shining where you will be shining it, and, what you are trying to SEE with it. Take an imaginary walk through the area...using your imaginary light as you go.
(I'll wait...)
OK, now that you have done that (If you have NOT, please, do it now....I'll wait again....):
How large a patch of light is projected on to what stuff, how far away?
Is there a RANGE of distances, and, size of the beam ON those targets that you imagined?
Tell us what you imagined, and what the light was helping you to SEE.
Pictures, videos, etc, ARE your best bet, at least to COMPARE the beams.
Goinggear is ESPECIALLY useful, as they
1) Do a TON of lights
2) Do the beam shots in the same locations, making it easier to COMPARE to OTHER beam shots.
Otherwise, Its VERY hard to find
1) Someone who HAS the lights you want compared
2) Has shot beam shots OF these lights
3) Has shot these beam shots in the same location or night so as to allow comparison of the beam shots to each other.
One guy might have one of them, shined into his backyard, another onto a wall, and a third at a tree or bush, etc...
If the target is small, you can't SEE what light PASSED the target because the beam was larger, just the lit target. This makes beams that are different, look the same.
If the target is too close, you can't tell the difference in throw, as ALL of them hit it hard enough to look lit, etc. This ALSO makes them look the same.
You need a large enough target, far enough away, so as to DELINEATE the beam performances...for a variety of beam types.
This is NOT an easy task, given the variety of beam types, power, etc.
If it helps you describe what you think you want....paste the pics of the light beams you think you like best (They are in the several threads you asked about this quest...), and ALSO some beams that you DIDN'T like.
This will help steer recommendations as well.
