You're smart to ask about output since dealer and manufacturer claims are often much higher than acutal. In another thread I revealed my foolishness in relying on advertised claim that the Ultrafire EMR1 puts out 200 lumens. In the $17 range, you should check out the 1X16340 "8W Mini CREE LED Digital Torch" at DX. The 1X18650 Ultrafire Alpha-C1 with a Q2 at Supertactical is nice at about $22. In the $25 range you will find two exceptional 1X18650 lights with bright white output, great beam pattern and two-stage reverse clickies. They are the Eastward YJ-18WA and Yj-18WF. Beyond these, you are paying for high quality HAIII bodies, not necessarily higher quality light. My 1X18650 LumaPower M1 and 1X18650 Dereelight CL1H, with a 5-mode Q2 P60 module, are both under $100. I actually like the latter more because it has a forward clickie with momentary and exchangeable P60 modules with a lower pricetag too. My personal experience is that over $100, you are buying a name more than better quality or output.
