Belt sander mod question
FredM
Houston, TX
Does anyone know of a good way to mod this belt sander
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=2485
to slow it down 3x or so?
Obviously a smaller pulley will work as would some electrical modification but I'm not sure which is easier. I have a lathe so in theory I could make a pulley but if someone has tried and knows it not worth it I will get one with a DC motor and PWM or something.
The pulley is the easiest/cheapest way to slow it down.
Or spend a bunch for a DC motor + PWM control.
Or replace the motor with a 3-phase motor & use a VFD.
Option 1 is the way to go.
I think so also but am worried about such a small pulley making an issue with slack in the belt.
After replacing the pulley, contact a power transmission dealer & tell them diameter of each pulley & center-to-center shaft distance. They will sell you the correct (shorter length) belt.
I have the Delta version of this belt grinder... the easiest way to slow it down is to change the drive pulley, which is about 4" diam. If you decrease the size of this drive pulley, you will need to either enlarge one of the other pulleys or modify the idler pulley at the top.
Another vote for a pulley change. BTW, I've had this exact sander from HF for about a year now and love it. An excellent bargain. :thumbsup:
Works with any universal AC/DC brush type motor,
I've never seen any stationary power tool with a universal motor. Portable power tools (woodworking router, electric drill, shop vac, etc) use universal motors, which normally turn around 10,000 rpm in a shop vac, 20,000 rpm in a router, and 30,000 rpm in a Dremel.
If any machine sounds like a shop vac when you hit the start switch, it has a universal motor.
I found some people that have modded the much more expensive (but probably worth it) Delta SA180 belt sander.
I also heard some bad things about the HF model along the lines of vibration and belt tracking.
Hey! Wait! That was MY suggestion!
" * Works with any universal AC/DC brush type motor, 15 amps and under "
The only question is whether it's a brush-less motor.
Dan
My understanding is router speed controls are only for shaded pole motors. You can't use 'em on a capacitance start motor, which this is. If you have a motor that starts up slow and gains speed like a grinder you can use them. Of course, they have to be properly rated for your horsepower app, but that is never no mind in this case. The manual shows a 124uF 250V start up cap.
Porter Cable makes an excellent belt sander with the bonus of a disc sander, it is a bit more money I am afraid, but a nice tool. It is a 1700rpm motor, but something like 3400 feet per minute? I dunno if that will help or not.
http://www.deltaportercable.com/Products/ProductDetail.aspx?ProductID=11470
yeah thats the one I just linked like ont he post right above yours.
Yah, I was agreeing with you, that they make a very nice product. If you pick it up please let us know how you like it. :)
Sorry I couldn't find any that had variable speed. Only the Makita portable 1" belt sander, and I didn't think that was what you wanted.
Since you stated other people modded it, I am guessing it is still faster than you want?
Sorry I am slow I didn't get that you were agreeing with me LOLz!
No I just didn;t want to pay three times the cost of the HF model. It gets down really low with their mods, they are putting 3 way pulley's on it to have it variable speed like the AC lathes have. Its just all told with those pulleys and the sander I'm looking at 160 minimum and the work to fit the pulleys, that doesn't even include belts.
Please tell me that folks are not paying $1,000 for a two inch belt grinder.
Yeah, it looks fairly solid, and I know that some parts are a hassle to make, but $750 for a single speed unit without a motor?
But wait! There's more! The VFD motor and controller package is only $1,088 more!
Is it just me, or does that seem.... excessive?
I would have gladly paid $1000 for my Burr King 482 (48" x 2" belt) ... but had to pay over $1600 for a new one.
My VFD was $350, and the 3 hp Baldor was about $100, so my machine total is just over $2k. Considering that it runs every day that I'm in the shop, it's been one of the best investments I've ever made.
The KMG is a nice machine, especially if you need a large diameter contact wheel for hollow grinding knife blades. There are plans to build a KMG copy, available on the web, which would allow some cost savings. You'd probably have $300-$400 in parts, not counting the motor (and VFD if you want variable speed). For me, the speed control is essential, and the Burr King, the Delta belt/disc machine, and my wire brush machine are all VFD controlled, running 3 hp motors.
Please forgive my ignorance, but what features / attributes of that sander make it worth so many times more than what I paid for my belt sander?
I probably should not ask, since I'm happy with what I have... ignorance is sometimes a good thing! But I like to know what defines a good tool, so I'll ask anyway.
Since the moving belt is the main consumable, and will fit on many different machines, that can't be it.
The bearings are off the shelf, but I've seen some seriously accurate, seriously expensive bearings. Is that where the money goes?
Daniel
The KMG belt grinder was designed for knife makers and industrial applications and is one of the best available. It is very versatile and easy to modifly,and will last a lifetime and priced accordingly.
