Re: BessieBenny's Budget LED (DX/KD etc) Flashlights Review Roundup (Part 9)
My MC-E Mini L2 Solarforce .. This will be my battery tester , Solarforce RCR123A's arrived this morning : Time to test batts .
http://www.photofreek.com/images/571_100_0276.jpg
[over-size photo replaced by link - DM51]
BB Budget Battery Test
1/ KD – PRCR123A 3.7v - 625mAh - $3.01 each
2/ Solarforce PRCR123A 3.7v – 880mAh - $3.95 each [ 800mAh claimed by seller ]
3/ Trustfire – PRCR123A 3.7v – 880mAh - $2.25 each .
4/ E-bay – RCR123A 3.7v – 1000mAh - $2.20 each.
5/ Ultrafire – RCR123A 3.7v – 880mAh - $3 each [ Ebay ]
6/ AW- PRCR123A 3.7v – 750mAh - $9 each
7/ Ultrafire – PRCR123A 3.7v – 1000mAh - $3.19 each
8/ Ultrafire – PRCR123A 3.7v – 880mAh - $2.50 each
9/ DX - RCR123A – 800mAh 3.7v - $1.64 each .
10/ Spiderfire – PRCR123A 3.7v – 1000mAh - $4 each
Just a quick note , most expensive is the AW , the cheapest is the DX and everything else falls in between , a few make the 1000mAh claim , Spiderfire - Flea-bay - Ultrafire , the rest seem to make reasonable claims .
With so much battery snobbery etc floating around , one thought it time to put some possible BS to bed . This to me seems like a good roundup of batteries , I know its not all of them , but there the ones that are the most available , though the AW's are not so easy to buy , nor affordable , but what would a battery test be without one ?
All the CR123A's have been fully charged and rested for 2 days .
I will start testing , and post results for each batt as its completed .
No1 KD – PRCR123A 3.7v - 625mAh - $3.01 each Length = 1.400inch Dia = o.650inch
Started @ Voltage 4.09 Amp draw 1.5
05 Minutes = V 3.90 A 1.6 ...Hot - The mini L2 gets hot after 3 minutes .
10 Minutes = V 3.74 A 1.4 ..." " "
15 Minutes = V 3.68 A 1.13
20 Minutes = V 3.47 A o.93 I noticed a bit of fade at this point .
25 Minutes = V 3.34 A 0.63 Flashlight is running much cooler
30 Minutes = v 3.17 A o.35 Just about at the end , not much output + cool running now .
35 Minutes = V 2.97 A 0.25 Amps start at o.25 but quickly drop to o.15 , id say the batt is just about exhausted .
No2 Solarforce PRCR123A – 880mAh - $3.95 each [ 800mAh claimed by seller ] Length = 1.350inch Dia = o.650inch
Started @ Voltage 4.10 Amp draw 1.8
05 Minutes = V 3.89 A 1.71
10 Minutes = V 3.83 A 1.59
15 Minutes = V 3.73 A 1.4
20 Minutes = V 3.51 A 1.07
25 Minutes = V 3.00 A 0.31
30 Minutes = V 2.71 A o.o6
No3 Trustfire – PRCR123A 3.7v – 880mAh - $2.25 each Length = 1.390inch Dia = o.655inch
Started @ Voltage 4.10 Amp draw 1.81
05 Minutes = V 3.86 A 1.67
10 Minutes = V 3.82 A 1.44
15 Minutes = V 3.68 A 1.32
20 Minutes = V 3.50 A 1.02
25 Minutes = V 3.04 A o.35
30 Minutes = V 2.77 A o.o8
No4 E-bay – RCR123A 3.7v – 1000mAh - $2.20 each. Length = 1.315inch Dia = .650inch
Started @ Voltage 4.11 Amp draw 1.77
05 Minutes = V 3.87 A 1.66
10 Minutes = V 3.81 A 1.57
15 Minutes = V 3.73 A 1.45
20 Minutes = V 3.60 A 1.23
25 Minutes = V 3.46 A 1.01
30 Minutes = V 3.28 A o.72
35 minutes = V 2.84 A o.17
No5 Ultrafire – RCR123A 3.7v – 880mAh - $3 each [ Ebay ] Length = 1.310inch Dia = .650inch
Started @ Voltage 4.11 Amp draw 1.76
05 Minutes = V 3.93 A 1.8
15 Minutes = V 3.70 A 1.47
20 Minutes = V 3.35 A o.8
25 Minutes = V 3.00 A o.1
No6 AW- PRCR123A 3.7v – 750mAh - $9 each Length 1.365inch Dia = .650inch
Started @ Voltage 4.12 Amp Draw 1.56
05 Minutes = V 3.89 A 1.51
10 Minutes = V 3.80 A 1.45
15 Minutes = V 3.74 A 1.39
20 Minutes = V 3.70 A 1.29
25 Minutes = V 3.54 A o.96
30 Minutes = V 2.95 A o.20
No7 Ultrafire – PRCR123A 3.7v – 1000mAh - $3.19 each Length = 1.450inch Dia = 0.660inch
Started @ Voltage 4.17 Amp draw 1.88
05 Minutes = V 3.91 A 1.69
10 Minutes = V 3.78 A 1.43
15 Minutes = V 3.75 A 1.3
20 Minutes = V 3.67 A 1.28
25 Minutes = V 3.23 A o.58
30 Minutes = V 2.85 A o.o6
No8 Ultrafire – PRCR123A 3.7v – 880mAh - $2.50 each Length = 1.430inch Dia = .655inch
Started @ Voltage 4.16 Amp draw 1.86
05 Minutes = V 3.90 A 1.63
10 Minutes = V 3.78 A 1.49
15 Minutes = V 3.74 A 1.35
20 Minutes = V 3.68 A 1.34
25 Minutes = V 3.44 A o.90
30 Minutes = V 2.88 A o.13
No9 DX - RCR123A – 800mAh 3.7v - $1.64 each Length = 1.340inch Dia = .650inch
Started @ Voltage 4.08 Amp draw 1.71
05 Minutes = V 3.86 A 1.74
10 Minutes = V 3.74 A 1.44
15 Minutes = V 3.06 A o.30 and quickly dropping .
No10 Spiderfire – PRCR123A 3.7v – 1000mAh - $4 each Length = 1.350inch Dia = .655inch
Started @ Voltage 4.08 Amp draw 1.68
05 Minutes = V 3.83 A 1.58
10 Minutes = V 3.78 A 1.51
15 Minutes = V 3.69 A 1.35
20 Minutes = V 3.55 A 1.02
25 Minutes = V 3.44 A o.86
30 Minutes = V 3.32 A o.58
35 Minutes = V 3.13 A o.33 but dropping ...
Done it ! :wave:
