Best 10440 cells for the Eiger Ultra X?
Wurkkos
Whitelight1
Well-known member
I have 4 Efest 10440 cells that are about 5 years old, and I am looking to get some new cells for the Eiger Ultra X. Does anyone know if there a fit issue with 10440 cells in this light, also looking for the best 10440's available.
thermal guy
Well-known member
ny
I had the same issue trying to see what 17500 would fit in my Logan. Apparently no one actually uses them in there’s and sticks with other options. Peak couldn’t even tell me. What I did was look at my AA which fit and got ones the same length. It’s the length that’s going to mess with you.so just find a 10440 that’s the same length as your AAA and you should be good.
Vemice
Well-known member
I have been using Soshine 10440s for a while with no problems. I even use them in my Logan 17500.
Whitelight1
Well-known member
Well... The Efest are 43.18 mm long, the Vapcell is 43 mm long, and the Soshine is 43 mm long. I am not sure about the quality of Soshine vs the other two brands. I would prefer the Efest. Efest and Soshine are both 350 mAh the Vapcell is 320 mAh.
If I knew the Efest wasn't too long I would get them. Since I already have some 10440 Efest I might wait and see if they fit and if they do order more of them.
