its nowhere near 200mw
what would be new about that :thumbsup:
just be happy its mabey around 80mw
if i remember right the amp draw with a 200mw lazer thing and its driver is about 1/4th of an amp right? and it should remain regulated to at least 3.6v. about any battery should be able to cope with that, even an older UF should be able to handle that. So i am leaning towards that aint the problem, unless you got a sicko one.
could be "either or" i think, untill you have another 18650 to test with.
a pila 18650 is protected has a good reliable cell item in it.
AW sells some good well tested protected 18650s in the marketplace
The correct trustfire can be an usable cell item
a UF will work good, just not for long and its often a sloppy build, but again a new one, charged and you tested the charge voltage, and it aint working, points to the pointer more.
but if you want best
you get a LG , Sony , Sanyo, Panasonice raw cell and put your own protections on it.
