Best AA Batteries for INCAN 5761 2D
bullettproof
What are the best batteries for an INCAN 5761 2D Maglite? I will be using fivemegas 6AA to 2D adapter. I was considering the Titanium 2700 mah but Im a NOOB and you guys no best. I want longest run time and a battery that can push out steady amps.
mikevelarde
SZ, China & Philippines(菲律宾)
It all depends on your own preference!!
For extended runtime, you can also consider powerex 2700 nimh AA.
For intermittent use,May I suggest Sanyo ENELOOP LSD(Low Self Discharge)nimh AA cell with nominal capacity of 1900mah.
I use eneloop for my mag85,ROP Hi, ROP Low, as well as the 5761 using the [email protected] and FM 6aa > 2D just like you!!:poke:
mikevelarde
ANDREAS FERRARI
The Great White North
I've been using Eneloops and RayoVacs Hybrids in my ROP's and Mag61 and both work great.One point of caution-the 5761 bulb is prone to instaflashing when you don't let the batteries rest for a few hours after charging.What I do is put the batteries in the freezer for 2 hours before using.
