remuen
In a few months the new 5W LS should be available. As far as I know it sucks about 750 mA at 6.8 volts. Therefore we need a DC-DC converter (booster) for all 2/3/4 cells applications and also for the 5 cells if using NiMH. Btw, I do know that 2C/2D cells will not be a really good solution because of the high current they had to deliver. So we have to concentrate more on the 3/4/5 cells.
As we all know it should be a current regulated booster. So we do have a new challange here in the CPF. I'm wondering who will solve this problem?
Has anybody already thought about which chip could be used best? The ZLT+ (with the ZXSC300) in its current design can't be used. We need at least a ZLT++ with an improved design if this is possible (other output transistor etc.)
Most of the Maxim IC's (eg. MAX1674) can't be used either to drive this new LS as they have a max. output voltage of 5 to 5.5 volts (voltage regulators) and cannot deliver the needed high output power. As far as I have seen only the MAX1698 would almost match our requirements. The min supply voltage of 2.7 volts would be no hindrance for a 3/4/5 cell flashlight but maybe the max supply voltage of 6 volts (dependig on whether alkalines or NiMH's are used).
Maybe we should take a closer look on some battery charger IC's which will probably come closer to what we are searching for?
