It's called
unobtanium. The term we use around work for the material we want to use, but doesn't exist. "What's that made of, unobtanium?"
I'll second Beryllium. But more pure, not alloyed with Copper. Lighter than aluminum & less thermal conductivity, but compared to any other material even AL & copper, it has better thermal properties relative to its density (more thermal conductivity & capacity per given mass). It is stronger than AL of the same thickness. But very expensive - $745/kg (!)
. And it is a carcinogen, so coat it in something!
Don't breathe the machining dust!
From Wikipedia:
Wikipedia said:
Beryllium has one of the highest melting points of the light metals. The modulus of elasticity of beryllium is approximately a third greater than that of steel (stiffer than steel). It has excellent thermal conductivity and is nonmagnetic.
At standard temperature and pressures beryllium resists oxidation when exposed to air.
Due to its stiffness, light weight, and dimensional stability over a wide temperature range (down to -240C), beryllium metal is used for lightweight structural components in the defense and aerospace industries in high-speed aircraft, missiles, space vehicles, and communication satellites. Several liquid-fueled rockets use nozzles of pure beryllium, such as the Saturn V.
"My flashlight is a missile!" :nana:
Beryllium Copper is good for a "normal"
material:
"Beryllium copper is a ductile, weldable, and machinable alloy. It is resistant to non-oxidizing acids (for example, hydrochloric acid, or carbonic acid), to plastic decomposition products, to abrasive wear and to galling. Furthermore, it can be heat-treated to improve its strength, durability, and electrical conductivity.
