BruiseLee
I do a lot of work on cars, my own, my family's, and my friend's. For awhile now I've been meaning to get a headlamp specifically for working on cars.
I believe leds are definitely the way to go. I can't tell you how many light bulbs I've blown in under an hour using a standard work lamp - that filament just can't take any shock, and when you are working on cars things are bound to get banged up a bit (I use a fluorescent worklight these days).
For me, having the batteries up front, not on the back of the head, is an absolute must. I'll tell you why. Because if you are lying under a car up on jack stands in your garage or driveway, it's going to be uncomforatable as hell to have a hard plastic battery compartment as a pillow, that's why! I've also spent a lot of time on the floor of cars under the dash installing head units, changing heater cores, master cylinders, etc. Again, this kind of work has the mechanic lying with his head on the floor.
Throw is not important for this kind of work. A bright flood would be a big plus working on engine compartments at night (ever notice how people's cars always seem to break down when it's dark?). Multiple levels of brightness would be a big plus, too, since you don't need a blinding amount of light to change a blown fuse under the dash.
Runtime isn't too important, since I figure any LED headlamp should be able to run for at least a couple of hours. If I can't fix it in a few hours, time to tow it to a garage!
Battery wise, I'm partial to AA only because I have a ton sitting around the house. But, I already have AAA and lithium 123 flashlights too, so those are definitely an option.
The thing is bound to get filthy with dirt and grease, but I figure most headlamps are made for outdoorsmen, so they should be ok getting covered with oil, antifreeze, power steering fluid, grease, etc.
What do you think guys? Any suggestions?
Bruise
Bruise
