Help Support Candle Power Flashlight Forum
Where do you get your callies customs 3100's, AW's, & redilast's? At the moment I am using Panasonic protected 3100's from Intloutdoor. I have also been using the solarforce 2400 protected battery's. Has anyone tested these?
it would be interesting to see some of the cells from last years test in the comparator.
or maybe retest some of them ?
The black one's.Which Panasonic 3100 cells, the blue or black?
As I am in Aus. there is not too many place's that sell the battery's that are mentioned in this topic in Australia.Where do you get your callies customs 3100's, AW's, & redilast's? At the moment I am using Panasonic protected 3100's from Intloutdoor. I have also been using the solarforce 2400 protected battery's. Has anyone tested these?
Hey Graham
There's a Top-Rated E-Bay seller in Sydney Australia (supersports600) that cells protected Panasonic 3100 cells under a brand name of Blazar, but which seem to get good reviews from buyers.
You could give this source a try?
Cheers
d337944
The black batteries that you have are pretty comparable to the Callie's Kustoms.The black one's.
According to some test I have seen there not hardly as good as they use to be. I do have several of the older ones that are a decent battery.It seems like the TrustFire 2400mAh cells have the best $/Ah ratio. I can't justify spending 5 times as much on a cell that doesn't even have twice the capacity.
I need something with at least 2500 mAh in 18650 cells.
I know Panasonic makes these 2900 mAh cells which would really rock except that they don't appear to be protected.
