Hi:
I have found Dow Corning "Molycoat" 55 (silicone) to be highly regarded among the paintball crowd. Underwater photographers and SCUBA divers, OTOH tend to use "Sea & Sea Silicone grease". Photo folks sometimes use greases recommended and supplied by their camera manufacturers too. Some are available from B&H Photo, Adorama, etc.
I was also considering Dow Corning High Vacuum grease 976V (also silicone).
Is it better to have a highly viscous grease? If so, 976V is about the best available. But I'm tempted to try the 55 since it's specifically designed for o-rings. However, the Molycoat 55 does have a property which concerns me. It "slightly swells" the o-rings for better sealing. But, being silicone, it does not break down the rubber. I'm not sure I want any swelling at all, since I generally want my lights to be easier turning, rather than tight. Though, with proper lube, they will probably be plenty easy to turn compared to their horrible dry condition now.
It seems clear that a silicone grease is best for o-rings, since neoprene or natural rubber rings will break down with hydrocarbon based greases. Only buna-N (nitrile), silicone, and PTFE o-rings are compatible with hydrocarbon greases. So if one doesn't know what their o-rings are made of, silicone offers the highest likelyhood of compatibility. Unless one has silicone o-rings, which is unlikely.
Does anyone here have experience using any of the greases mentioned?
Note I am *not* talking about grease appropriate for threads that must mate as well as conduct electricity. That's another subject... I know Nyogel is popular, but it is hydrocarbon based, so probably shouldn't be used on o-rings unless one knows for certain they have nitrile.
Thus, if one has both unknown o-rings *and* electrical threads in a flashlight, it seems two greases are needed!
Any other favorites?
