I believe the Centuras are approximately 8500mAh and somewhat low self discharge, but not Eneloop type LSD, so keep that in mind.
The Premiums are closer to 10,000mAh, IIRC, but will discharge faster.
Then there is the light blue basic Tenergy D/C NiMH, but I don't think I'd go that route, just from anecdotes I've read here over the years.
If you're using your light a lot, everyday, the Premiums might be the ticket. If you're letting the light sit in anticipation of the zombie apocalypse, then the Centuras should be OK.
Personally, I never use my 6D MLs and I almost wish I hadn't spent the $37 on the two TerraLux modules, but I have them and I'll use them as loaners. I ran movie theatres in sketchy parts of town in the mid 90s and having one of those 6D was a visible deterrent and a useful tool in the business, but heck they're just too big and heavy.
Back then, I did a quick cost/benefit analysis and determined that I could buy 20 alkaleaks, for a third of the price of NiMH, which is what I did. I really should get the NiMH Ds, because I have a couple of 02 Cool 12vdc/9vdc fans that take D batteries, or run off of a 120vac wall wart. I have a couple/few SLA/AGM 12vdc lead batteries for them, so it's still a moot point for me.
Anyhow, you just need to figure out what works for you and whether you want to use your 6D often, necessitating 'a' decision as illustrated above, in my case.
I even bought two C/D cradles that work with my Maha C9000 and Opus BT-3400, but I never got the batteries, lol.
Chris
